-   -   PVC to Cast Iron (http://www.diychatroom.com/f7/pvc-cast-iron-6292/)
oakj 02-04-2007 01:29 AM
PVC to Cast Iron
I'm going to vent a fixture. I'm using pvc pipe for the vent and need to connect it into a 2" cast iron hub.
What is the best way to do this? Rubber gasket or led? :(
jproffer 02-04-2007 02:48 AM
They make epoxy (of sorts) to put together PVC and cast. Ask at a plumbing supply house.
Ron The Plumber 02-04-2007 08:28 AM
If it's just a vent use a 3" x 2" fermco, the 3" side will fit tight over the hub of the cast pipe, you will need to force it on but it will go over the hub.
jproffer 02-04-2007 12:14 PM
:thumbsup: Didn't think of that.
Go with Ron's idea. Much easier to work with than that epoxy shi...uhh...stuff.
