Pvc And Cast - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2011, 10:11 AM   #1
Pvc and cast
I have to connect some PVC to existing cast under my slab. Would I be better off cutting the cast and joining them with a boot or should I slip a gasket into hubbed fitting on cast and insert my PVC through that? I'm not sure which method would be less likely to leak under the slab. Thanks!
Lew04 is offline   Reply With Quote
Old 04-17-2011, 10:28 AM   #2
Jack of all trades
danrb007's Avatar
Send a message via Yahoo to danrb007
Get a rubber boot that fits the PVC and the Cast. Make sure the cast is cut clean and straight. Insert the cast halfway in and the pvc halfway in so the 2 ends are together. Tighten the clamps as tight as possible without stripping them.
danrb007 is offline   Reply With Quote
Old 04-17-2011, 01:43 PM   #3
Thanks, but should I use the rubber boot or the kind that has a stainless steel band around the rubber?
Old 04-17-2011, 02:47 PM   #4
Jack of all trades
danrb007's Avatar
If it was me if the cast and the pvc are the same diameter I would use the one with the steel band. But either one works good as long as you get a good seal.
Old 04-17-2011, 04:36 PM   #5
Thanks again, that's what I'll do.
