Putting In A 2nd Floor Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2013, 09:25 AM   #1
putting in a 2nd floor bathroom
Hi,
I am trying to put in a bathroom on the 2nd floor of my cape cod. Currently there is piping for a toilet and a cold water supply on the one end of the bathroom near the stack. Why they only put in a toilet i have no idea. I am trying to put a sink and shower on the other side of the bathroom 9 feet away. The joists are 2x8's 16 inches on center and run perpendicular to the direction i would need to run the waste and supply lines for the sink and shower. For a 2inch waste line going 9 feet there is no way that i can keep the hole more than 2 inches from either edge of the joist for the whole run. None of the plumbers seem terribly concerned about this. Does anyone have advise on options? Does sistering the joists allow you to go closer to any of the edges?
The other option is to put a second waste line on the other end of the "bathroom". I have a closet below the side of the bathroom that i want to put the sink and shower. Is a 2 inch waste line ok to drop down into my basement? I would then have to somehow tie that into a 4 inch cast iron main stack right where it exits the house. How difficult is that? Thanks
bigpoppadiesel is offline   Reply With Quote
Putting Window in Garage Wall palmernjp Introductions 0 09-29-2009 05:18 PM
putting stone vaneer on painted cinder block dlmont75 Carpentry 2 06-28-2009 09:04 PM
putting up car shelter mudpaws Building & Construction 1 04-27-2009 11:32 PM
furnace not putting out heat diff HVAC 1 01-07-2006 12:20 PM
Help putting an internal door through to the garage from the hall vix92008 Building & Construction 4 02-17-2005 01:46 PM
