Push In Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2008, 04:29 PM   #1
push in toilet flange
getting ready to finish off a basement bathroom, and looking at toilet connections. Anyone used the push in gasketed flanges from sioux chief? Are there any problems with this?
mbaker76 is offline   Reply With Quote
Old 12-03-2008, 12:17 AM   #2
Do you have 4" pipe to connect it to? According to their website (which is hard to navigate for specs) these push in flanges only fit this size pipe. probably to prevent undersizing the drain line. When I have installed piping for future use in concrete floors, I always used rubber or styrofaom around it. This allowed a good seal, no chance of the concrete breaking the pipe and also room to remove some of it to install the flange.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-03-2008, 01:20 AM   #3
Im pretty sure its 3" pipe but yes it has a styrofoam cap around it to protect it when poured.
I thought I saw a slip on flange that was for 3" pipe on their website somewhere. I jsut though that would be easier than trying to glue something else on, just slip it in screw it down and go.
Old 12-04-2008, 02:30 AM   #4
Rewards Points: 2,906
Oatey makes a floor flange that will slip into and tighten up inside a 3 inch toilet drain pipe, and from my experience tightening their standard "Twist & Set" floor flanges into 4" PVC pipe, it's super secure and I'd trust it in my own building.
http://www.oatey.com/Plumber/Shared/...et+Flange.html
Note that the Twist-N-Set PVC floor flanges come to fit both 3" and 4" ID pipe.
Nestor_Kelebay is offline   Reply With Quote
Problem toilet flange dougm Plumbing 5 11-22-2008 08:32 PM
Replacement toilet flange for Iron rgb407 Plumbing 9 08-27-2008 08:40 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 09:19 AM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 12:37 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 10:41 AM
