Purpose Of Packer Washer In Shower Stem - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2016, 06:02 PM   #1
gilloz's Avatar
Rewards Points: 22
Purpose of packer washer in shower stem
I would like to know what the primary purpose is of the big fat fiber washer inside the shower valve stem. Some are 1/4 " thick while others are 1/2" thick. Should they be replaced every time you replace the shutoff washer at the end of the valve stem?
gilloz is offline   Reply With Quote
Old 01-20-2016, 06:14 PM   #2
joed's Avatar
Rewards Points: 12,912
The packer washer on the stem keeps water from leaking around the stem.
Old 01-20-2016, 06:19 PM   #3
gilloz's Avatar
Rewards Points: 22
Thanks for your response. Then, what keeps the faucet from turning very easily as oppose to having some resistance to make it turn slow? My hot water valve almost spins freely as oppose to the cold water valve which requires a small amount of force to turn it?
Old 01-20-2016, 07:15 PM   #4
WhatRnsdownhill's Avatar
Rewards Points: 2,220
the packing does wear out over time, and there should be a nut to tighten down the packing, hence the name..
WhatRnsdownhill is offline   Reply With Quote
Old 01-20-2016, 07:51 PM   #5
Rewards Points: 582
Picture of what you have...
Old 01-20-2016, 11:27 PM   #6
joed's Avatar
The packing usually has some lubricant(graphite or teflon) in it that allows the stem to turn. If you tighten the packing nut too tight the valve will get stiff to turn. If you loosen it too much the valve will leak.
Drywall disintegrating near shower A_DAB_will_do Drywall & Plaster 8 12-02-2015 10:14 AM
Shower Head (over head) dripping while using Hand Held Shower Head HTFreak Plumbing 14 09-29-2015 03:46 PM
Shower Panel Install Gone Wrong Bushido_Ben Plumbing 10 11-03-2013 07:23 AM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Possible Shower Stem Problem mikeylikesit580 Plumbing 5 01-22-2011 03:08 PM
