Purpose Of This - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-06-2010, 01:53 PM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
Purpose of this
Doing a reno on a ex-rental property, noticed this in the basement. What would of been the purpose of adding a half ass broken vent to the drain right before it goes into the ground and ties into the weeping/sewer system?
ryanh is offline   Reply With Quote
Old 09-06-2010, 02:33 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
looks like it is a washer drain. Any water or power connections for laundry appliances close by?
Old 09-06-2010, 03:02 PM   #3
Owner
LateralConcepts's Avatar
Yup, that's a drain for a washing machine. Not a vent.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 09-06-2010, 08:33 PM   #4
I'm gonna vote on condensate or w/m. Is the furnace close by, or clear tubing hanging from the ceiling?
the_man is offline   Reply With Quote
Old 09-06-2010, 10:18 PM   #5
Always learning...
fetzer85's Avatar
Rewards Points: 262
Agreed, looks like a washer drain.
If you're not using it, you need to cap it. The basement at my wife's work smelled like sewage and she asked me to check it out before they called in a plumber. I found a drain that appeared to be an old AC condensate line but there was no water in the trap. I could put my hand over the pipe and feel air rushing up, and it smelled awful. Easy fix for a smelly problem.
fetzer85 is offline   Reply With Quote
Old 09-06-2010, 10:30 PM   #6
ryanh's Avatar
Rewards Points: 154
No there is no washer plug at all, but theres a dryer plug about 10' away and its 6' from the ground LOL.
Good call on the washer though, its definally what its there for, just goto to run a plug. thanks
Purpose of condensate drain/neutralizer sj22 HVAC 11 02-10-2013 01:22 PM
Limestone slab over main sewer purpose? britastic Plumbing 0 03-20-2010 05:37 PM
Purpose of 30amp single pole breaker Giles Electrical 5 02-16-2010 09:30 PM
Purpose of gaps between sheets of plywood? diy888 Tiling, ceramics, marble 35 02-16-2009 11:01 AM
Is all purpose drywall compound not strong enough? yummy mummy Building & Construction 3 04-23-2008 12:35 PM
