Old 10-25-2007, 12:56 AM   #1
Purple Primer everywhere??!!!
Hello i was installing some solar on my pool and i got some purple primer on my filter and some other parts. How do i get this darn stuff off of things. i tryed paint thinner but didnt seem to work. Let me knwo if anyones had any luck with products??
amarlls is offline   Reply With Quote
Old 10-25-2007, 07:27 AM   #2
RippySkippy's Avatar
I would try PVC cleaner, I doubt though you'll ever get it all off.
RippySkippy is offline   Reply With Quote
Old 10-25-2007, 12:01 PM   #3
If you find anything that removes it, let us all know. This primer actually starts a chemical action so the pipe and fitting are basically welded together with the glue. I have found nothing that will remove it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-25-2007, 08:09 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
That purple PVC primer/cleaner can be scrubbed off of some things (like your hands) IF it is scrubbed off while still wet.
Once it dries, it's purple forever. LOL
I suppose that it could be sanded off with fine grit sandpaper, if someone really felt the urge.
Mike
Mike Swearingen is offline   Reply With Quote
Old 10-26-2007, 09:46 AM   #5
Buy another bottle of primer and a paintbrush.... at least it won't be spotted purple anymore I can solder copper just fine but I'm like a kid with fingerpaint when it comes to PVC welding.... purple everywhere!
moneymgmt is offline   Reply With Quote
Old 10-26-2007, 11:35 AM   #6
Longtooth's Avatar
Paint over it. PVC is not sunlight resistant and the new paint will help it last.
Longtooth is offline   Reply With Quote
Stucco over paint, will Primer work ? iMisspell Building & Construction 5 05-14-2009 05:07 PM
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 05:32 PM
Zinsser Primer on Wood Veneered Furniture cupcake Painting 3 10-05-2007 03:07 PM
Primer peeled Project Girl Painting 10 08-26-2007 04:39 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 07:38 AM
