Purging Hot Water Risers To Baths - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2012, 12:47 PM   #1
biggles's Avatar
purging hot water risers to baths
saw "Ask This Old House" segment on this problem of running the hot water for showers and sinks taking 2-3 minutes to get hot water up there.old HWH was in the middle of the basement directly under the baths upstairs 1/2"...new tankless was installed on a basement wall and vented out on the gas and the contractor went to 3/4" copper on the hot water out.basiclly the pump (115V) is installed under a sink and pushing of a button sends the COOL water on the HOT water riser right over into the true cold side and a sensor shuts the pump off when it feels hot water at the pump...so the purge is complete and HOT water is upstairs...my question can a pump actually push the riser cooler water into the cold side of the house?? anybody try this might catch a video of it will add to this...the This Old House Plumber gut Rich T.did it so his word is GOD or what!
Old 03-18-2012, 02:06 PM   #2
Rewards Points: 636
i have not but watts backs a system like that. here is link.
http://www.watts.com/pages/_products...s.asp?pid=6677
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-18-2012, 03:58 PM   #3
biggles's Avatar
just wondering how the pump sends the cooler water into the col water side against the pressure there.found that show it's up on my newer thread on the hot water up top
Old 03-18-2012, 04:22 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
So you think that this could be used on a tankless WH?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-18-2012, 04:57 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 996
In theory it should work with an aquastat only problem is that water heater would be working to keep that water at the preset temperature defeating the supposed purpose of a tank less unit.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-18-2012, 05:05 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,264
I have this system in my 80 foot ranch style house. WH in garage, master bath at opposite end of house. Pump is in crawl space under bath. Button on side of vanity. Push button and 45 seconds later -- Tada -- hot water. Plumbing is 3/4 inch PEX between garage and bath.
Works great.
Coastal South Carolina
Old 03-19-2012, 08:36 AM   #7
Rewards Points: 1,548
When all the water faucets are turned off while the main valve is still on, the pressure everywhere in the system is the same.
Also at that time it is possible to pump water in either direction around any loop (without check valves) that may exist in the plumbing system in without running against pressure.
If a faucet is on while a recirculating pump is in action, water to be recirculated may go out the faucet instead of going around the loop. Alternatively some incoming water may go around the loop in the same direction the pump is pushing instead of opposing the recirculation. Exactly what happens depends on how far the faucet is opened compared the gallons per minute rating of the pump.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 07:17 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
