Purging Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2012, 05:13 AM   #1
011010100110111101100101
Rewards Points: 160
Purging gas line
I just installed all new gas lines. I spoke with the inspector yesterday, and he told me just put a gauge on it and make sure it holds 5-10 psi for 10 minutes.
The pipes I bought are kinda dirty, and I used a lot of pipe dope. (when I say pipe dope, I mean specifically a can labeled for use with LP gas)
So, I'm just asking about the purging process. Should I remove the caps on the drip legs and provide continuous compressed air for a while, or is there a specific procedure you guys use to purge any crap/extra dope out of the system?
I'm convinced I got probably a small amount of dope into some of the fittings/t's because I went a little crazy with it.
-- Joe
anesthes is offline   Reply With Quote
Old 03-21-2012, 05:23 AM   #2
Remodeling Contractor
purge the pipes by attaching a vacuum pump to the lines and removing any contaminants
Charge line from car to trailer Scardey eCat Electrical 7 10-24-2010 10:38 PM
Water line to fridge, actually -in- 'subflooring', not under?? Anonyone Plumbing 5 10-16-2010 06:31 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 07:53 AM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
