Old 10-20-2009, 11:22 AM   #1
Default Purging Forced Hot Water System
My forty year-old heating system is forced hot water by gas. It is two zone, first and second floor. Some of the heat registers on my second floor are cold. It seems that the circulators are working, as I can see the motors running. A friend told me to purge the system to insure that I have no air locks.
I have an idea as to how this done, however I hesitate to do it without some instruction. I know, for example that I must introduce water to the system to move the water and air along. I also know that I must allow for the air to escape the system by attaching a hose to the faucett connections that appear along the heat pipes (in the basement) and running the water out of the system. There appear to be four such fawcett connections
I don't know whether there are other considerations, so I thought that I would ask.
For example, do I purge through each faucett connection? If not, how do I identify the correct faucett connection?
Essentially, how is the purging accomplished?
Thanks,
DJ
dwlodyka is offline   Reply With Quote
Old 10-20-2009, 02:06 PM   #2
On a hot water heating system, there should be bleeder valves on each radiator. Your use of the word "registers" is confusing. If you have baseboard heat, each one should still have bleeder valves. Air rises to the highest point of the system, so look there.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-20-2009, 02:39 PM   #3
Maj,
The system is baseboard heat. Forced hot water. I've looked at the registers, I don't see any bleeder valves. That would make it too easy! What do I do in trhe absence of bleeder valves?
Old 10-22-2009, 09:41 AM   #4
Default Look
Did you look under all the metal panels sometime there are little panels at the end of the radiator where a small bleed valve is.
SULTINI is offline   Reply With Quote
Old 10-22-2009, 09:56 AM   #5
I looked, but Ill look again. From what I'm hearing, there must be something there, I just haven't seen it...
Thanks.
More On This Topic
Fresh water is an absolute must when traveling in an RV. It's important that you know how to clean the existing system through routine maintenance and keep freshwater flowing through your RV's pipes. You also can install additional filters to your RV... Read More »
Hello, my name is Jennifer Warr and I am here as an expert of representing the mineral kingdom in behalf of Expert Village. When we consider all of the elements in the universe which is earth, air, water, fire and we understand we are a part of all of... Read More »
One of the great things about snorkeling is the simplicity of the sport itself and the gear you need. As long as you're snorkeling in a relatively warm climate, all you need is a bathing suit and the snorkeling gear. Your gear typically consists of a... Read More »
Hi! I’m William Myers with Subaru for Expert Village. We’ve checked your battery level, now if you had to add water to your battery all you would do is remove the cap and add your distilled water right in there. That’s how you would add... Read More »
Repair corroded lines and in your car air conditioner when repairing the accumulator; learn how in this free DIY auto-mechanic video from our expert in automotive AC repair and maintenance. Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Hot Water Heating Problem....please help gor4200 HVAC 5 10-13-2009 12:59 PM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 05:01 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 10:09 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
