Pump For Wet Bar In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2013, 10:38 PM   #1
Rewards Points: 111
Pump for Wet bar in basement
Hello,
I was wondering if anyone had any recommendations on which enclosed pump systems are good to use to help drain a wet bar sink in basement.
Breaking up concrete to tie into bathroom plumbing is not an option, so I was going to install an ejector pump below the sink and pump the water into my existing 4" main line, and also tie into existing 2" vent. I am looking for which products are best ones to use (quality, last a while, not too loud, etc.) I can not use the vent-less type systems, inspector said it needs to be tied into vent.
Looking for something like this: http://www.amazon.com/Zoeller-105-00.../dp/B0009TCDZ2
Thanks,
Steve
svaic00 is offline   Reply With Quote
Old 06-03-2013, 04:54 AM   #2
DIY staff
Rewards Points: 7,174
That Zoeler unit is a good one----Use that and you will be in good shape---
Javiles (06-03-2013)
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Sewage ejector pump in basement johnd2 Plumbing 8 12-07-2013 10:48 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Do I need seperate vent stacks for basement pump and basement sink? twinfins Plumbing 5 12-07-2010 11:28 PM
Basement Sump Pump & Dimpled Plastic Membrane Interior Questions cloves Building & Construction 0 03-24-2010 09:44 PM
