Pump Sewage Uphill? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2009, 12:40 PM   #1
pump sewage uphill?
hi,
i am building a new cabin in the mountains and have a existing septic tank that is aprx. 200' from the new cabin and the new cabin is aprx. 10' below the grade of the existing septic tank... i am looking for the simplest... maintenance free way of connecting the new toilete to the existing septic tank... i am off grid and use solar and have a back up generator... but was wondering if there might be a system the uses water to pump it uphill to the tank instead of a electric pump? my water is via a spring with my holding tank aprx. 150' above the cabins... so i have around 80psi of water pressure... can anyone help me with some ideas?
thanks in advance,
josh
Last edited by panahead; 05-02-2009 at 12:43 PM. Reason: needed to add a thanks... added
panahead is offline   Reply With Quote
Old 05-02-2009, 04:03 PM   #2
I am only aware of one type water powered pump. It is a sump pump but you would need a macerating (grinding) pump for solids. This type also uses 2 gallons of water to pump one gallon. You may want to check out the Sani-flo website since they make macerating toilets with pumps. Not cheap, but may be your answer.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-02-2009, 05:17 PM   #3
maybe i should ask... what are my options? so far what i have seen are variations of a holding tank then a sump pump that sends the waste up hill... "Quik Jon"or with or without a grinder or a grinding macerator with a sump pump (ie: used in boats etc) what manufacturers are best.. the most reliable... does the system smell? how noisy is it? how long does the pump run? etc... etc...
thanks...
josh
Old 05-02-2009, 05:50 PM   #4
or maybe something like this?
Little Giant 9S-SMPX-LG, Unassembled Package w/ 20" x 30" Poly Basin, 1 Piece Cover w/Bolt-On Flanges - 9S 4/10 HP Sewage pump, 2" Discharge, 2" Check (509108)
Tags
thanks in advance
Uphill Sewage? robmac Plumbing 12 07-30-2010 10:47 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
Sewage Pump Installation blueboy27 Plumbing 3 11-06-2007 12:43 AM
Sewage pump for home Unregistered Plumbing 2 02-28-2005 09:54 AM
Sewage pump problem Unregistered General DIY Discussions 1 10-03-2004 10:52 PM
