Pump Setup Drain In The Basement? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-27-2008, 03:34 PM   #1
liscenced electrician
Rewards Points: 538
pump setup drain in the basement?
I have an unfinished basement, that im planning on putting the washer/dryer in. Problem is that the drain line is above the basement level. So what would i need to do to pump the water out?
also, its not critical at this point, but later down the line i want to put a full bathroom down there when the basement gets finished, what should i do for that?
jimmy21 is offline   Reply With Quote
Old 07-27-2008, 03:49 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
www.saniflo.com
Mike Swearingen is offline   Reply With Quote
Old 07-27-2008, 04:21 PM   #3
Rewards Points: 538
i think thats what i need, any idea where to buy them online and how much they cost?
Old 07-27-2008, 04:34 PM   #4
Rewards Points: 538
well im looking at that sanivite pump. It looks like it would be the best for my application and fairly cheap compared to the others. it says washing machines must drain to a laundry tub first, what the heck is that?
Old 07-27-2008, 07:47 PM   #5
Send a message via AIM to Marlin
Laundry tub:
How high do you need to pump it? If it's only a couple of feet the washing machines pump will be fine. If it's more then that you need to install a laundry tub first. This prevents the pump from getting full of suds and causing a backup.
If you're not ready to install the bathroom at the same time as the laundry what I would do is get yourself a cheap pump that doesn't have to get buried. Then when you install your bathroom use the saniflow toilet or an underground pump (which I recommend).
Marlin is offline   Reply With Quote
What is it? A Sump Pump or Tub Drain ameleus Plumbing 13 05-04-2008 07:12 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
