Pump Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2010, 06:51 PM   #1
pump problems
i have a well and a pump, last nightmy water quit working--no water from any fosset. the pump continues to run but no water comes out. i unplugged the pump because it was getting hot. i have four kids and i don't have the money to hire a plumber, if you have any ideas on how to fix this problem i am in need of some advise. thanks, Rita
ritam.rhino is offline   Reply With Quote
Old 07-08-2010, 08:10 PM   #2
You need a well driller rather than a plumber.
If the pump was hot, that tells me it is an old style pump on an older well.
Could be a well problem.
If you can get it running, just draw the water you need until someone looks at it.
Unplugging it was the right thing to do.
Mr. Green is offline   Reply With Quote
Old 07-08-2010, 08:24 PM   #3
Licensed Master Plumber
Shallow well pump so, ( in order of likelihood )
1 - Foot valve has failed and pump lost prime
2 - The internal jet on the pump is plugged
3 - There is no water in the well
4 - There is a suction line leak
5 - The pump is worn out
Unfortunately, most of those conditions will require the services of a professional, either plumber or well/pump guy
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 07-08-2010, 08:42 PM   #4
It also could be a plugged screen in the well. This would take a well rig to pull the screen, if it will come out.
Old 07-08-2010, 09:29 PM   #5
Yes it could be that also. No clue where she's from though. Around here, nobody screens wells, we drill through the bedrock and set 8" steel case. though she may have a driven point
Old 07-08-2010, 09:40 PM   #6
I love when people post a question & then are off the site within the same minute the thread was posted
Old 07-08-2010, 10:24 PM   #7
We drill both bedrock intake and drift wells.
A little south of me if you drill in the rock, you will get brine.
A little to the north, gypsum.
My well is 320 ft in the bedrock, great water.
The glaciers were not kind to all of us.
Old 07-08-2010, 10:25 PM   #8
Oh well, we still had a good time......
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
GFCI problem with pond pump sandsmarc Electrical 21 04-05-2013 01:51 PM
well pump electrical multimeter question tpolk Electrical 21 04-28-2010 11:37 PM
Sump pump issues GeorgeHuhges Plumbing 3 10-19-2009 03:43 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
