Pump On Icemaker - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-28-2013, 07:48 PM   #1
Pump on Icemaker
I am looking at a new icemaker for my home. I see that some units have a pump and some say "gravity." What is the difference. Also, how do I discover which type I have now.
Thanks.
maccmacc is offline   Reply With Quote
Old 05-28-2013, 07:52 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
It's not for the water....
Some ice makers are down below...if you have a bottom freezer...hence, there has to be a way to get the ice up to the door at the proper level for the user....so it needs a 'pump' or some type of mechanism to bring it up.
I would be inclined to think that it's just something else to break....
ddawg16 is online now   Reply With Quote
Old 05-28-2013, 08:48 PM   #3
I'm with you. Thanks for your help.
Tags
gravity , icemaker , pump
ejector pump suddenly tripping gfi lilargie Electrical 4 04-24-2012 05:15 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 11:23 AM
Drainage under packaged heat pump salonica HVAC 18 12-25-2011 07:07 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
