Pump Fitting To Water Plants. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2009, 10:17 PM   #1
Pump fitting to water plants.
Hi guys I am new here and my first question is as follows:
I have a little DC waterpump that pushes about 3L/min. I need this water to be diverted equally into 4 different tubes. So basically what i need is something like this:
qqqqqqq /====o
qqqqqqq/ /====o
i=====( )
qqqqqq\ \====o
qqqqqqq\====o
where 'i' = water out from the pump to the splitter and 'o' = water out from splitter. q is just formatting
What is something like this called? It needs to fit the output of the pump which has a diameter of about 6mm. Cheers!
Yid1 is offline   Reply With Quote
Old 01-09-2009, 02:26 PM   #2
Remodeling Contractor
its called a manifold. Check out sites selling irrigation supplies.
Old 01-09-2009, 03:54 PM   #3
biggles's Avatar
OK i had to look at a drill bit chart to see how big 6MM was you could build your own with plastic tubing and some brass slip on fittings so from left to right the L______I____(I)____I______L *<<(turn it) (L) are 90 degree (I) are TEEs this one (I) is also a tee but faces the pump so that is the water being sent into the header.the 4 discharges will be the 2(L)s,and the 2(I)s .you might consider sizing down the 4 takeoffs so the header pressure is more distributed evenly.HD has all this stuff .....6MM is like 1/4 plastic tubing size ....down here.
Old 01-09-2009, 04:13 PM   #4
Whatcha growin?
Reilley is offline   Reply With Quote
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
Sump Pump Spraying Water lancoll Plumbing 1 12-12-2007 02:18 PM
Why no water hours after friend pulled our pump? sheriffherself Plumbing 4 11-19-2006 07:10 AM
