Pulling up pump now its stuck -HELP plz
Sometimes we DIY'ers get ourselves into deep doggy doo!
Its likely that the pump wires enter the pump near the outside and when an attempt is made to pull on the pump it will catch on the inside surface of the well casing.
The ideal way to resolve this, would be to have a look with a TV camera and create a plan of action.
Obviously, pulling the cable isn't going to work. The pump being down at the bottom is likely immersed in water and may negate the use of the TV camera.
Broken bolts in metal parts are often removed using a tool called an EASYOUT. This, of course wouldn't work in your case, but something similar, could used to worm its way into the the pump opening or into the broken end of the pump line.
Did the pump line break? Or did it come away from the pump?
If the line broke, how much is still attached to the pump?
The weight of the water in the line is considerable and may have contributed to the water line separating. This weight will have to be taken into consideration also.
Experienced well people may be able to quickly resolve your problem and it may be best to call in some expert assistance.
