Proximity Of Copper Water Supply To Electrical Fixtures - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2011, 12:14 AM   #1
Rewards Points: 1,062
Question
proximity of copper water supply to electrical fixtures
i was wondering if there are any code regulations mandating a certain minimum distance between copper water supply and electrical fixtures. i am dealing in some tight spaces and don't have much alternative for where to run pipe relative to lighting fixtures. OK, i could but then i'd have to zig-zag making more joints than the straight shot, which i am trying to avoid at all costs, for elegance and minimalism.
see picture attached.
thanks
proximity of copper water supply to electrical fixtures-plumbing_lighting.jpg
Old 09-12-2011, 06:31 AM   #2
Check local code, but my gues is they should not be touching, that is all. The problem with touching is galvanic action that could cause holes.......then there is a major problem.
Old 09-12-2011, 06:35 AM   #3
Rewards Points: 1,216
That "B" vent pipe must be kept at 1" from all combustibles, they make supports just for that.
COLDIRON is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
any problem with cold water branch before water heater? jasperjodo Plumbing 3 06-08-2011 08:01 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-28-2005 11:05 PM
