#1 |
Proximity of Bathroom Exhaust fan to HVAC Supply Vent?
I am installing a new bathroom exhaust fan and would like to place it near, but not in the shower. Where I would prefer to place it is whithin 1.5' of the AC/Heating supply vent.
Is there a minimum distance required between the fart-fan and the AC/Heating vent? |
#2 |
Since both ducts should be insulated, proximity should not be an issue. The heating/AC ducts is insulated to prevent losses. The fan duct is insulated to prevent condensation from forming.
#3 |
Xtreme DIY'r
I think your concern is pulling the heated air & exhausting it outside ?
#4 |
Yup. I talked to an HVAC guy I know since posting this and he recommended 3' spacing. Problem is to give it 3', I either have to place the fan inside the shower, which I don't want to do, or it will be about 8' from the shower. I don't mind placing it 8' from the shower but will it be effective? It's sized correctly at 110 CFM for the 100 sqft room. BTW, there is a window in the shower so will the fan being 8' from the shower be OK?
#5 |
Xtreme DIY'r
One bathroom the fan is over the edge of the shower/tub
2nd one is maybe 3' from the shower We don't really use the fan in the winter, partially heating with wood we need the humidity from the shower At my last house I heated mostly with wood & had forced hot air So again did not use the fan in the winter Not sure where you are located, do you need to remove the heat when the heat is running? Is the heat vent "pointed" towards where the fan woudl be ? Have you checked the humidity in the house ? Is the heat vent also an AC vent for the summer? Even at 8' away with the bathroom door closed it will suck the mosture laden air out My concern is that 8' away it might have a tendency to pull air from the heat vent And of course the fan should only run for a short period of time normally |
#6 |
I'm in Southern California. Both the exhaust and the vent are/will be located in the ceiling. Yes, the vent is for central air and heat. We don't heat the house as much as we cool it. We also have a humidifyer tied to the HVAC system since it gets pretty dry out here, especially in the winter.
What I may actually do is relocate the vent further from the shower and then place the exhaust where the vent used to be. That vent has a damper so I can always adjust the flow should it need it since I will be shortening the duct to relocate it. I had originally thought to do this but wanted to find an easier route. But, as I have always known, most often the hardest way is the right way. |
| Display Modes | |
| Gas furnace exhaust vent question | nowell | HVAC | 7 | 01-30-2012 09:31 AM |
| Wiring in New Addition? | sandyman720 | Electrical | 6 | 11-27-2011 04:34 PM |
| Vent Bath Exhaust to Cold Air Return? | brandon272 | HVAC | 12 | 03-28-2011 06:11 AM |
| Gas HW Heater exhaust vent caulk | jbaker1516 | HVAC | 2 | 06-17-2009 04:39 PM |
| extending my direct vent exhaust tube | brianbh | HVAC | 5 | 02-13-2008 04:25 PM |
