View Poll Results: Can you tell me where to get a chrome offset tailpiece?
No way! 0 0%
I could, but don't feel like it. 0 0%
Stop dreaming, that's eliminated by the code! 0 0%
Sure, I'll post the info. 1 100.00%
Multiple Choice Poll. Voters: 1. This poll is closed
Old 05-10-2011, 09:45 PM   #1
Pros have seen an Offset tailpiece for Lavatory ?
I need an offset tailpiece to solve a trap fitting problem. Has anyone seen one that looks similar to the one in the picture I've posted here.
My plumber roughed in the drain too close to the sink drain and also angled it *towards* the drain so I can't even reverse the J bend to get more distance. All the plumbing will be visible as the sink is a wall mount.
Any suggestions or links will be appreciated,
Pros have seen an Offset tailpiece for Lavatory ?-offset-drain-tailpiece-study-10.jpg
gregr is offline   Reply With Quote
Old 05-10-2011, 10:52 PM   #2
nap
You talking to me?
nap's Avatar
what's wrong with the one you have in your hand?
Old 05-11-2011, 08:22 AM   #3
Plumb or Die!
Never seen one of those, but ADA compliant wall hung lavs require an offset tailpiece that uses 2 90 degree bends that will fix your problem, provided you don't use a pop up drain plug assembly.
plumber666 is offline   Reply With Quote
Old 05-11-2011, 09:47 AM   #4
fabrk8r
fabrk8r's Avatar
Most plumbing supply houses have chrome double offsets couplings but they have radius bends rather than mitered.
Keep in mind the ones I am talking about are couplings and not actual tailpieces, so you will have to have do some adapting. I've had to cut tailpieces down in order to use them in most cases as they are about 10" long.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 05-11-2011, 07:57 PM   #5
So I don't have to be the fix it guy next time, what is the geometry advice you would teach a new plumber about positioning the ABS stub out for a wall lav drain that will be 6" from the wall? I want to know what a professional would tell an apprentice.
I just soldered that mitered tailpiece together to see if it would work. It might, but I've ordered a double right angle ADA drain that also my just work and I can shorten the horizontal piece to help it. But I'll need to re-thread the brass tube if I need to shorten it...
Old 05-11-2011, 08:23 PM   #6
call me E
TheEplumber's Avatar
I would go about 2.5" to either side of center. This will allow me to turn the trap sideways and still have enough to attach to the trap arm
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
gregr (05-12-2011), oh'mike (05-11-2011)
Old 05-12-2011, 04:14 PM   #7
Thanks Eplumber, I think I have it figured out...
I would add for a close-to-wall drain:
If the sink needs a centered stub out and trap: The marvel nut can be no closer to the drain line than the length of the J bend plus the deformed section of the bend on the waste arm. You may need to expose only the threads of the marvel.
If you want an aligned trap and If the stub out can't be centered: put it to the side with the least interfering objects and align it *exactly* with the drain line farther away than the length of the J bend plus the deformed section of the bend on the waste arm.
If you want the stubout close to the drain and the trap unaligned: Put the stubout to the side *no farther* than the length of the J bend when the stubout is perpendicular to the wall, or angle the stubout toward the drain but at least 1" off the drain line so the trap may be installed reversed. Plan for the marvel threads to be away from the drain line the length of the J bend plus the deformed section of the bend on the waste arm *with* the trap bent.
Let me know if that seems right, I may need to send a diagram...
Old 05-12-2011, 10:38 PM   #8
call me E
How are you going to re-thread the brass? Are you referring to the end that threads into the drain?
Old 05-13-2011, 01:51 AM   #9
I was Imagining I'd need to find a 1-1/4" 28TPI die, or pay a guy with a machine shop to do it.
Tags
professional, tailpiece, trap
Sink tailpiece leak? kcrossley2 Plumbing 11 01-09-2011 10:03 PM
Tile Roof - To offset or not to offset tiles kowtow Roofing 3 12-07-2010 11:17 PM
Offset bearing wall benjamincall Building & Construction 13 07-06-2010 02:14 PM
Tailpiece and Flange separation scotdo Plumbing 2 02-04-2010 06:31 PM
Offset Tub Overflow, Plus Narrow Tub thebigsee Plumbing 0 01-27-2010 02:52 PM
