Proper Way To Connect A Horizontal Branch? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2012, 06:37 PM   #1
Plumber
TheEplumber's Avatar
Rewards Points: 552
Proper way to connect a horizontal branch?
Cut out a 4" horizontal CI building drain with a 1.5" galv. horizontal kitchen branch. We decided this wasn't legal
Old 01-13-2012, 06:40 PM   #2
Rewards Points: 13,446
Are you asking a question or making statment about what you found?
Old 01-13-2012, 06:42 PM   #3
Rewards Points: 582
ok so what next...
Old 01-13-2012, 07:15 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 994
Expert workmanship, applies to the new code..
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-13-2012, 10:04 PM   #5
Plumber
Rewards Points: 552
Yea, I had to stop and admire the brazed joint on the cast iron.
Old 01-13-2012, 11:34 PM   #6
Looks pretty.
VIPlumber is offline   Reply With Quote
Old 01-14-2012, 06:16 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,450
Originally Posted by VIPlumber View Post
Looks pretty.
Looks more like JB Weld.
ddawg16 is online now   Reply With Quote
Old 01-14-2012, 06:45 AM   #8
Rewards Points: 352
mighty putty strikes again!
plumberinlaw is offline   Reply With Quote
Old 01-14-2012, 11:20 AM   #9
Plumber
Rewards Points: 552
That joint is over 50 yrs old. It does look like putty though.
Horizontal Studs jburchill Drywall & Plaster 1 07-06-2011 12:06 PM
Max horizontal load on vertical basement support beam supa Building & Construction 8 02-27-2011 01:51 PM
best way to secure horizontal 2 X 4s.... joetab24 General DIY Discussions 23 12-14-2010 11:56 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Adding a phone line to an older connect point cramsmith General DIY Discussions 3 11-23-2005 11:35 AM
