Proper Tool For Cutting Off Toilet Screws - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2011, 09:32 AM   #1
Rewards Points: 150
proper tool for cutting off toilet screws
Hi! I have recently set a new toilet and am trying to figure out how to properly cut the bolts off that come up thru the flange. I tried a few swipes with a hacksaw and was afraid I would round out the hole the bolt head comes thru from below, so I quit. These are the 2 bolts on each side of the toilet that get covered with the little caps. Thanks! Do they make a taller cap so you don't have to cut the bolts off? If not, what is proper way!
guest is offline   Reply With Quote
Old 09-07-2011, 09:36 AM   #2
Rewards Points: 252
Put the nuts on first and then use the hacksaw?
shazapple is offline   Reply With Quote
The Following User Says Thank You to shazapple For This Useful Post:
Bud Cline (09-07-2011)
Old 09-07-2011, 09:40 AM   #3
DIY staff
Rewards Points: 7,174
Put the nuts on first---
A dremel with a cut off wheel works
A pair of linemans pliers work if you have strong hands
Bolt cutters.
Old 09-07-2011, 09:51 AM   #4
Rewards Points: 150
Thanks! You guys sure responded quick, raining here today so I am looking for inside projects to finish. Thanks again!!
The Following User Says Thank You to guest For This Useful Post:
oh'mike (09-07-2011)
Old 09-07-2011, 01:56 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
I've always just used a hacksaw. Those brass toilet bolts are easy to cut off.
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-08-2011, 08:57 AM   #6
Plumb or Die!
I have a mini hacksaw I always use for these. A normal hacksaw is a bit long for some toilets, you have to be careful to not touch the porcelain with the blade. It will scratch and leave a permanent mark.
plumber666 is offline   Reply With Quote
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 11:14 AM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 11:12 AM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
