Proper Plumbing? Need Clarification - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2011, 03:33 PM   #1
proper plumbing? need clarification
#1 - the flow is from right to left - I was told by a city plumbing inspector that on a horizontal run such as this, a 90 degree elbow was not permitted - but 2 - 45's should be used.. is this correct? any minimum distance between the 2 - 45's required?
#2 - flow is from right to left - same question above about the 90 degree elbow on the right, and the t-connector on the left - should that not be a Y-connector?
#3 - this is a horizantal run, flow is right to left - should the 3 or 4" T-connector not be a Y-connector instead?
#4 - flow in large pipe is right to left.. is this a proper connection?
#5 - flow is from right to left.. is this a proper connection?
thanks for any helpful comments...
djgap is offline   Reply With Quote
Old 06-23-2011, 03:53 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 830
You must use a long sweep 90 or 2, close coupled 45's on horizontal runs.
Horizontal branch lines connecting to another horizontal line must connect with combination wyes and 45s. San tees not allowed.
Old 06-23-2011, 04:12 PM   #3
i should clarify, i am in Ontario, Canada, in case the applicable plumbing codes are any different elsewhere....
Need advice on plumbing for new washer AliceT24 Plumbing 9 02-17-2011 10:43 AM
Bathroom remodel, sink plumbing dschmid Plumbing 3 02-03-2011 08:32 PM
Proper Duplex Plumbing michaelcherr Plumbing 6 01-26-2011 09:50 AM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 03:04 PM
