Proper Name For Tub Drain Stopper - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2008, 10:23 AM   #1
Rewards Points: 101
The handle on the tub drain will not stay in the open position. Last night I took it off and it just seems worn on the back side. It is the type that drops down inside the front of the tub and has a metal cylinder on the end. I was wondering of someone could give me the correct name so when I go to the plumbing suplly I know what I'm asking for. I guess I can also bring it with me.
jte1130 is offline   Reply With Quote
Old 01-14-2008, 10:33 AM   #2
Oldguy
Rehabber's Avatar
It's called a 'triplever'
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-14-2008, 10:51 AM   #3
Rewards Points: 101
Thanks.
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
floor drain with a stopper amakarevic Plumbing 3 08-13-2007 12:12 PM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 03:15 AM
I am doing the happy dance..I Finally got the tub drain cleared, whew!!! Woodpecker Plumbing 20 06-09-2007 11:20 AM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
