Proper Grounding Technique For Trac Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2011, 10:55 PM   #1
Proper grounding technique for trac pipe
Had a plumber install trac pipe in a home and did not ground it. Can someone tell me the proper way to ground it, as well as what type of ground wire to use 12? 14?
thanks!
brokenhammer is offline   Reply With Quote
Old 11-08-2011, 11:37 PM   #2
Is this pipe electrically conductive?
If not, did it replace metal pipe which was electrically conductive? If yes, you are best to call an electrician and have him check your entire grounding system.
Billy_Bob is offline   Reply With Quote
Old 11-09-2011, 12:03 AM   #3
Code calls for it to be grounded in my region. I have an electrician lined up to do the work, but he's never done this on trac pipe before.
Old 11-09-2011, 01:04 AM   #4
Here are instructions for your electrician...
http://iaei-michigan.org/Product_Info/CSST/Tracpipe.pdf
And main power should be off when working on ground wires. Also protective rubber gloves should be used. Pipes can be energized by faulty equipment at a neighbor's house. I would use large #10 copper ground wire (get out your checkbook!). (Best to check with your local electrical inspector's office for bonding requirements and ground wire sizes.)
And all the other grounds on the plumbing should be checked. Best is if there are two ground rods at the main electrical service placed 6 ft. apart.
proper roofing technique blazer7 Roofing/Siding 2 06-14-2011 05:20 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 10:49 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
