Proper Drain And Vent Help Needed - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2010, 11:38 AM   #16
Proper drain and vent help needed
So the upper part of wye would feed toilet and horizontal end of wye would feed sink and tub? I've only got 8" joists, can I get all that in there? Thanks
papisox is offline   Reply With Quote
Old 11-03-2010, 09:26 AM   #17
Plumb or Die!
Yes to the plumbing part. You must keep the pipe that goes to the sink tee 2" to be a legal wet vent. Even if you could keep the 3" for the toilet jammed into the joist space I doubt I'd want to drill 2 3/4" holes through the joists for the sink drain pipe. Head to the DIY carpentry for that stuff though. Good luck!
plumber666 is offline   Reply With Quote
Old 11-03-2010, 09:52 AM   #18
thanks again. please see attached pic, i know its rough, but hopefully workable. So i'm using a sanitee 3x3x2 where it enters 2nd floor, and then a wye for sink and tub, any special kind needed? Then a regular 90 at the toilet? And for the 1st floor sink, i don't have access behind that and there is a large window above it across kitchen. Is there any other way to vent that? Thanks
drain to drain to vent? ryanh Plumbing 0 07-12-2010 01:07 PM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-17-2008 12:11 AM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 11:26 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 11:35 PM
