Proper Drain For Relocated Washer - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2013, 03:49 PM   #1
Rewards Points: 12
Proper drain for relocated washer
I'm considering moving a washer from downstairs to the space almost directly above it (garage). Getting water to it is not hard, but I wanted to ask about the drain. I can access the current washer drain pipe from the new location, but it's not a straight shot; there going to be an angle to one section of the pipe. Hopefully the picture shows pretty clearly: my proposed new drain piping in green, existing in blue. Any thoughts, affirmative or otherwise, are appreciated! PS. I know it should be 2" drain pipe, but the existing is 1 1/2 ". I can replace it with 2 without too much trouble, if the consensus is that it's necessary.
CA_wolverine is offline   Reply With Quote
Old 06-23-2013, 05:24 PM   #2
MarginallyQualified
Rewards Points: 2,464
Any thoughts...
Don't forget extending all that for the vent.
Adding utility sink for washer drain dcj710 Plumbing 16 03-22-2013 06:52 PM
Septic odor from washer machine drain TMC Plumbing 4 02-02-2012 07:40 PM
Water and drain hookup problems with washer and septic system. Snav Appliances 4 01-27-2010 11:01 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 10:35 PM
