Propane Vs. MAPP Torch - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2011, 05:08 PM   #1
Rewards Points: 1,062
Question
propane vs. MAPP torch
someone told me that it's better for a sweated copper joint to use propane than MAPP. is that true?
that sounds weird cause i've been successfully using MAPP for two years as it burns a hell of a lot hotter and gets the job done faster. e.g. i can sweat a 1/2" joint with MAPP in less than 10 sec whereas it takes almost a minute with propane.
Old 10-11-2011, 05:12 PM   #2
AlbacoreShuffle's Avatar
I'm a Mapp Man !
Try sweating a 1 1/2 " copper pipe with propane.
Its Ok if your paid by the hour. lol
AlbacoreShuffle is offline   Reply With Quote
The Following User Says Thank You to AlbacoreShuffle For This Useful Post:
amakarevic (10-11-2011)
Old 10-11-2011, 05:49 PM   #3
Wink
did it before i discovered MAPP... would take about 5 min per joint...
Old 10-11-2011, 06:48 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 904
Use to use propane all the time. 1/2" thru 2"
Its the tip size that counts.
I prefer to use acetylene when I can tho
Old 10-11-2011, 06:48 PM   #5
Lightfoot's Avatar
Rewards Points: 272
yep, mapp for me.
Lightfoot is offline   Reply With Quote
Old 10-11-2011, 07:19 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 2,112
Mapp......and it smells so nice.....................................NOT
Old 10-11-2011, 10:50 PM   #7
MAPP for hard to reach places and acetylene for the big stuff.
VIPlumber is offline   Reply With Quote
Old 10-12-2011, 05:43 AM   #8
DIY staff
Rewards Points: 7,174
Mapp is no longer available----some patent holder BS.
Now you can get MAP but it is not as hot as the old MAPP.
Old 10-12-2011, 10:44 AM   #9
JOATMON
ddawg16's Avatar
Learn something every day......
Would never have thought to look it up until now...
MAPP gas is a trademarked name belonging to Petromont, previously to Dow, for a fuel gas based on a stabilized mixture of methylacetylene (propyne) and propadiene. The name comes from the original chemical composition: methylacetylene-propadiene propane. MAPP gas is also widely used as a generic name for UN 1060 stabilised methylacetylene-propadiene (unstabilised methylacetylene-propadiene is known as MAPD). MAPP gas is widely regarded as a safer and easier-to-use substitute for acetylene. In the spring of 2008, true MAPP gas production ended when production was discontinued at the only plant making it. Current products labeled ""MAPP" are in fact MAPP substitutes. These versions are stabilized liquefied petroleum gas (LPG) with high levels of propylene.
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 04:42 PM
Filling a 20lb propane cylinder off a 1000 gallon tank--anybody done it? jbeall Building & Construction 26 12-27-2011 11:30 PM
chimney liner, excuse for propane furnace upgrade? bubbler HVAC 0 09-16-2011 07:58 AM
Where to get U shaped propane torch AllanJ Tools 3 04-03-2011 07:21 AM
gas (propane) cooktop off a BBQ tank pstock Appliances 0 06-26-2010 09:21 AM
