Propane Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2009, 05:37 PM   #1
sweaty
Rewards Points: 276
Propane Tank
I just hooked up a new propane tank to my grill. Should I have used teflon tape? Also, is the old tank good for anything? Recycling? Money?
sweaty is offline   Reply With Quote
Old 06-07-2009, 09:23 PM   #2
no you should not use tape and yes the old tank can be exchanged for a new full tank that would have cost you less then buying a new tank alone
clasact is offline   Reply With Quote
Old 06-08-2009, 08:20 AM   #3
No tape or dope needed since it is a friction type fitting. If the old tank has been equipped with the new fill valve, you can have it refilled. If not, you can take it to a propane dealer and "maybe" get something for it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Propane Tank for BBQ Irregular WayPeter General DIY Discussions 4 03-03-2009 01:28 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Propane tank was empty boiler does not start schrubber HVAC 3 12-30-2008 04:36 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
propane tank jmgasior Plumbing 1 08-02-2008 04:25 PM
