Propane Lines In An RV...Flare Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2008, 11:28 AM   #1
Propane lines in an RV...Flare Fittings
I'm doing a van conversion that involves plumbing for LP gas. I'm having trouble with my flare fittings. My trouble comes when I try to hook up my copper pipe to my appliances. I have soft copper tubing coming off my shut off and running to my appliances (stove and fridge). When I hook up the flare fitting at my appliance it seems to go together ok, but when I leak test with soap and water I have a slight leak. I am NOT using tefflon tape or pipe dope on the flare fittings.
Any tips, tricks, insight into how to install flare fittings would be appreciated.
K-mann is offline   Reply With Quote
Old 09-15-2008, 11:42 AM   #2
Try using a piece of emery cloth on the face of the flared copper. Sometimes the flaring tool will leave a ridge on the end. Doesn't take much to cause a leak since it is a metal to metal connection.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-18-2008, 08:55 AM   #3
Problem was I was flaring my copper tubing too much.
Old 09-18-2008, 09:06 AM   #4
Glad you got it figured out. Now you know where I got m signature from.
Finding Property Lines kypper Landscaping & Lawn Care 18 08-07-2008 04:18 PM
Grinding stump but how deep are gas and electric lines buried? jbk Landscaping & Lawn Care 1 08-02-2008 11:46 AM
Blue Chalk Lines on concrete Triple L Flooring 3 10-09-2007 05:50 AM
Propane heating questions Badfish740 General DIY Discussions 1 09-25-2007 07:46 PM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 04:23 PM
