Propane Line For A New Gas Cooktop? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2011, 02:34 PM   #1
propane line for a new gas cooktop?
I'm preparing to have a new gas cooktop installed. I've run the 120V line for the igniter. I have propane already at my house for a clothes dryer and a fireplace. I'm not sure what type of line needs to be run for the propane?
The dryer looks to be 1/2 rolled copper from the tee in the tank line up to the dryer(then the flexible hose into the dryer).
The fireplace looks to be the same copper off the tank line, then converted into some type of flexible pvc/plastic, the black iron in the fireplace itself up to the unit.
What is appropriate for propane for a cooktop?
Can the same rolled copper be run or does black iron have to be used?
tmorriss is offline   Reply With Quote
Old 03-23-2011, 03:05 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 358
Ayuh,... That's what Mine is....
1/2" soft copper, "T"'ed to the stove, 'n dryer...
All flare fittings...
Old 03-23-2011, 03:37 PM   #3
I think mine is smaller than 1/2".
The instruction manual should have a table. You also need to change the orifices if they haven't been.
pyper is offline   Reply With Quote
Old 03-23-2011, 03:41 PM   #4
Unfortunately, the instructions only cover the actual hookup of the cooktop (regulator, shutoff, etc etc)
It assumes a pre-existing gas line.
Yes, the unit has already been converted for propane. I"m just trying to find out what is the acceptable material to use for the line to the unit.
Old 03-24-2011, 08:44 AM   #5
Plumb or Die!
Soft copper with FLARED fittings is the way to go.
plumber666 is offline   Reply With Quote
Small underground propane leak, worth fixing? Dave Carney Plumbing 5 07-05-2010 07:03 PM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 09:09 AM
Natural gas line????? figs Plumbing 1 06-14-2009 02:13 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
