Old 09-18-2012, 04:08 PM   #1
Propane Line for 30" Stove
hello all,
I am adding a propane tank for my stove only. The location of the stove is right outside of the tank location. I'm guessing max run would 4ft.
Can I buy that much flexible pipe at home depot?
do i need a shut off at the tank and at the stove?
The stove came with the conversion for NG to Propane?
Thanks,
Chip from Baltimore
chipraynor is offline   Reply With Quote
Old 09-18-2012, 05:01 PM   #2
I can't address your questions, but have you checked to see if you can legally hook up your stove yourself?? You're in MD, after all.
Old 09-18-2012, 07:47 PM   #3
Not sure how it works were you are but here you need a permit, and a licenced plumber with a gas licence or the gas company has to do it.
Not sure why there's a ? after the statment is there a propane conversion kit with it.
Most places want soild black iron pipe ran to the stove run behind the wall, a shutoff, then a flex line from the shutoff to the stove.
Old 09-18-2012, 08:16 PM   #4
call me E
TheEplumber's Avatar
Originally Posted by chipraynor View Post
hello all,
Thanks,
Chip from Baltimore
Do yourself, family and you neighborhood a favor and hire it done.
Ever seen a propane fireball?
Regulations are strict and fines are expensive and home owners probably won't cover it
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (09-19-2012)
Old 09-18-2012, 10:34 PM   #5
You can't run flex straight from the tank to the stove, no matter how short of a run it is. It amazes me that HD and the like now sell CSST, but when I was installing, even though I was (and still am) a ticketed gas fitter, I had to be certified through the manufacturer.
hvac benny is offline   Reply With Quote
Old 09-18-2012, 10:43 PM   #6
no disrespect......this is not a diy project.....propane is very dangerous...strict codes....a tank has to be regulated for proper operation and delivery of gas to the appliance..... please listen we won't steer you wrong...we have your safety in veiw...ben sr
ben's plumbing is online now   Reply With Quote
Propane line to house - permit needed? jackwashere HVAC 3 09-17-2012 08:49 PM
gas line rough in height for dryer and stove? graysqwrl Plumbing 3 12-31-2011 08:21 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Diy propane stove help LAFORD1986 Appliances 1 01-03-2010 01:52 PM
Stove Gas Line mrlloyd Appliances 1 04-23-2009 05:41 AM
