Old 04-26-2007, 09:48 PM   #1
Propane hot water heater
All,
My 6 yr old propane hot water heater doesn't ignite reliably. The pilot is on, there is plenty of propane, the exhaust blower is working fine. The igniter even works fine when I power cycle the unit.
Symptom is: Once every couple of weeks, we notice the water is only lukewarm. I go downstairs to the water heater, and find the exhaust blower going, the pilot on, but no ignition of main burner. Seems like it must have been in that mode for hours. I think the thermostat must be going bad. When I unplug AC power to the unit, and replug, the igniter will ignite the main burner and I am OK again for another week or so, until the same symptom reappears.
Any ideas? Bad thermostat? Or do you think it is a faulty gas valve?
Phil
philmeister is offline   Reply With Quote
Old 04-26-2007, 10:41 PM   #2
Welcome
Check the thermocoupler.
brownie is offline   Reply With Quote
Old 04-29-2007, 01:28 PM   #3
how do I do this? do you mean thermocouple?
Old 04-29-2007, 08:20 PM   #4
You will find a small copper line comming off the valve body. It will run to where your pilot is. Their is a probe that sticks in the pilotlight. This copper line and probe is what you want.
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
