Propane Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2013, 12:18 PM   #1
Rewards Points: 27
Propane gas line
I am wanting to install black iron pipe inside my house to replace my current lp lines. Currently I have 1/2 O.D. copper line running from the tank to the house. This line is T'd underground and splits to two sides of the house for a toal of 10ft to the T then each split is 10ft. One split goes to the stove and that is it. The other split goes to a manifold and comes out 3/8 O.D. to my waterheater, a five brick heater and a three brick heater. The waterheater and 5 brick heater sit together and the three brick heater is 16' away. Total length of current system is 50'. BTU load is 180k.
I was wanting to replace all of this with a 10ft line to the house then all black 1/2 pipe to each appliance and relocate a few. The total length would be 125' with the longest run being 80' to a gas log fireplace that will be added in the future. Since I don't have the fireplace yet the longest run is 33'.
I spoke to the local gas company and they had no clue but I am allowed to run the lines myself and they will pressure test it when I am done.
Propane tank is a 250 gallon above ground tank
kujo is offline   Reply With Quote
Old 04-02-2013, 01:33 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 612
Ayuh,.... Black iron pipe is 'bout 1000 times harder to install, with absolutely No added benefit...
If yer needin' more volume, go with bigger copper....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
jagans (04-02-2013)
Old 04-02-2013, 02:11 PM   #3
Rewards Points: 27
I don't believe i need anymore volume as everything currently runs just fine and has for the last 20 years. I was installing the black pipe because the current lines come thru 3" above the bottom plate of the house which sits at ground level and has rotted. So I am moving everything off the ground and instead of having copper running up the outside of my interior walls I was going to put the black pipe inside the walls. Everything I have found online is about natural gas pipe sizes so I was wondering if 1/2" is big enough for propane? It is definetly an upgrade in size and volume from what I have now
Old 04-02-2013, 03:17 PM   #4
Rewards Points: 706
If half inch copper is currently doing the job I can't see a problem with half inch black pipe. If I had something around my homestead that valuable I'd sell it to pay for the pipe.
Old 04-02-2013, 06:46 PM   #5
Rewards Points: 636
just google propane gas sizing chart
i use gastite flash sheild flex pipe products they have sizing charts on their web site also
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Main water line, meter to house ckc Plumbing 15 09-28-2012 10:15 PM
Propane Line for 30" Stove chipraynor Plumbing 5 09-18-2012 10:43 PM
Line to line load on a MWBC? rjniles Electrical 13 12-09-2011 08:09 AM
Proper Water and Gas line bonding. John318 Electrical 5 11-16-2011 12:19 PM
Small underground propane leak, worth fixing? Dave Carney Plumbing 5 07-05-2010 07:03 PM
