Problems Replacing Two Handle Shower Faucets - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2009, 01:43 PM   #1
Unhappy
Problems replacing two handle shower faucets
hello,
i recently replaced my old/gnarly/outdated two-handle shower faucet handles with two new lever handles. my old set was a price pfister with very limited faucet options, so the only way to get a brushed nickel finish (to match the shower head) was to buy all the pieces from the stems to the handles separately.
the problem is that the universal fittings for the levers are made of plastic that won't grip the end of the stem adequately. everytime we go to turn the lever handle, the plastic part just slides around without turning on the water.
does anyone know how i can keep my modern handles but get a better fit to the stems? i'm willing to buy a kit if there is one in the brushed nickel finish.
bear creek is offline   Reply With Quote
Old 02-02-2009, 02:24 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 602
Ayuh,...
You'll never make it Right, using Mismatched piecs....
My guess is,... If you want brushed nickel finish, you may Have to swap out the Whole Faucet...
Old 02-03-2009, 11:11 AM   #3
thanks....
thanks for the tip...by "swap out the faucet" do you mean get a set where the stems, handle, etc all come together? to clarify, we don't actually have a faucet, just the shower head and two handles since it's a stand-up shower.
any ideas about where i can get a brushed nickel two-handle set?
Old 02-04-2009, 07:41 AM   #4
Try the manufacturer of the valves.
Revue is offline   Reply With Quote
Tags
plumbing , shower , universal faucet handles
Shower faucet problems Dmaxmama Plumbing 1 11-27-2008 08:22 PM
Are shower water problems caused by old pipes? bathroom nightmare Plumbing 17 02-02-2008 11:39 PM
two handle shower faucet to single handle GLASSMAN1 Plumbing 2 01-31-2008 09:08 AM
Replacing damaged shower wall tiles kevind Flooring 4 11-20-2006 01:18 PM
Replacing damaged shower wall tiles kevind Remodeling 3 11-15-2006 11:36 PM
