Problems Removing Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2012, 05:00 PM   #1
I have a one piece tub/shower unit in my bathroom. As you can tell from my picture my drain is corroded. I figured easy fix, I would buy another Lift N Turn bathroom trim kit from Home Depot. I also bought the Tub Drain Removal Tool. Figured it would make it easier.
Problem is I can not remove the drain shoe (I think that is what it's called the metal piece you still see in the photo zoomed in). I tried using that tool with a wrench would not move. Used a screw driver, no movement. Even tried the screw driver and used a hammer hitting the screw driver to try to get it to move. It has not moved at all and I am afraid I will break it even more. One of the four crosses are already not connected. The others are pretty thin. I am trying to turn it counterclockwise.
Any suggestions on what else can be done? I am not a highly skilled DIY person but I can follow instructions. Trying to do whatever I can so I don't need to call a plumber.
Guess another question is does this one piece drain even removable? I would assume so because not sure how else they could connect it.
Thanks for any help you can provide.
Problems Removing Tub Drain-drain-resized.jpg   Problems Removing Tub Drain-resized-tub.jpg
nicemann is offline   Reply With Quote
Old 10-23-2012, 05:39 PM   #2
Rewards Points: 13,748
Any access under it? Older ones have a nut under the tub holding it in place.
Old 10-23-2012, 05:58 PM   #3
House was built in 2002 and no it can not be accessed from below. It is on a second story floor but there are no panels to get to it.
Old 10-23-2012, 07:04 PM   #4
I gave it more umph, put my whole body into it with my feet braced on the side of the tub. I was afraid of breaking the drain but figured what the heck. I was able to get it loose and replaced it with my item from home depot.
If I have any other issues I will be back in the future. Hopefully I will be able to help also.
Old 10-23-2012, 07:37 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 682
You probably know how to swear like a plumber now
Old 10-23-2012, 07:40 PM   #6
Rewards Points: 582
good deal ..i was going to tell you to don't be afraid put some a$$ into it ...ben sr
Old 10-27-2012, 10:39 AM   #7
Tag for results, want to replace mine and I bought the same tool.
toastandjam is offline   Reply With Quote
how to replace bathtub drain with out removing tub? frank snell Plumbing 1 10-09-2012 11:50 AM
Drain Problems jugornot Plumbing 4 11-30-2011 10:18 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
Water and drain hookup problems with washer and septic system. Snav Appliances 4 01-27-2010 11:01 AM
washing machine drain vent problems rebelbull Plumbing 7 03-29-2009 09:18 AM
