Problems Removing Hot Water Tank Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-17-2010, 12:27 PM   #1
Problems removing hot water tank fitting
Tank is 10 years old. I'm replacing the 1/2" line into the tank with 3/4". I don't want to bust the tank fitting when removing the pipe fitting. The pipe goof is holding real good! Any recommendations? Any plumber tricks?
Spastic is offline   Reply With Quote
Old 07-17-2010, 01:40 PM   #2
Civil Engineer
Rewards Points: 4,560
Personally I wouldn't touch the fittings on a ten year old tank, they would have a high probability of breaking off inside the tank. Simply cut the pipe about 6 inches from the tank, and install a 3/4 inch to 1/2 inch adapter. No need to mess with the tank. When the tank fails, which it likely will very soon, extend the 3/4 inch line all the way to the new tank.
Old 07-17-2010, 05:56 PM   #3
Daniel,
I want to get rid of the 1/2" bottleneck through the water heater. I have a new spa shower connected with 3/4" and would like to crank on those jets.
I took out a dremel tool and made several cuts most of the way through the nut without hitting the connector thread. Then I pried the copper nut apart with a screwdriver. I couldn't locate my nut splitter (which probably wasn't big enough anyway).
Dave
Fleck Water Softener not softening & too much water in brine tank april66 Plumbing 2 02-01-2010 12:12 PM
Water tank problems chapmanm02 Plumbing 5 04-29-2009 08:11 AM
Need help with smelly and black well water!! HABSFAN2006 Plumbing 20 04-27-2009 11:54 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Hot water tank leak Bill46 Plumbing 1 08-20-2008 10:34 PM
