Problems with my toilet flushing
I'm wondering if the line between your house and the septic tank is partially clogged. When was the last time you had it cleared?
Maybe the toilet isn't flushing properly because the water is backing up in that line.
Try this:
Fill up two or three 5 gallon pails with water.
First thing in the morning, after that main line has had all night to drain, pour the first of the two pails into the toilet bowl as fast as it will take the water without spilling water all over the floor.
If the toilet flushes fine, then immediately start pouring the second 5 gallon pail into the bowl. If the toilet bowl starts filling up with water and the flushing stops, then you know the problem is that the drain piping is full of water. It may take a third pail to fill up your house's drain piping up to the toilet. Stop pouring water into the bowl immediately when you see that the water isn't going down because a high water level in the toilet bowl can cause the water to puncture a hole through the wax seal under your toilet.
Alternately, try flushing the toilet before and after your washing machine pumps 25 gallons of water into your drain piping. If the main drain line to your septic tank is clear, the water should be able to drain away as fast as it's pumped in.
Bashing my head against the walls in some of the internet's finest chat rooms.
