Problem With Toilet (vent Problem?) - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2012, 11:10 PM   #16
Rewards Points: 616
can you get pics
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-08-2012, 11:11 PM   #17
Originally Posted by jaydevries View Post
so what did he suggest
The particular company that snaked the line had no further suggestions.
Another plumber replaced roughly 10 feet of the waste line. That helped for roughly 15 flushes, then it was back to the same routine.
branch155 is offline   Reply With Quote
Old 03-08-2012, 11:12 PM   #18
GC/Master Plumber/Mech
Rewards Points: 560
The question about paper was because Charmin paper seem to cause more issues here.
I would pull the toilet and camera the line. To me it sounds as though you either have some sort of hang up in the line or the is a low spot in the line.
If after you have a camera view there is nothing then I would look at the toilet again and then the venting
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-08-2012, 11:14 PM   #19
Thanks for the advice. My next step is to get a camera view.
Old 03-08-2012, 11:17 PM   #20
Rewards Points: 560
You want a camera view from the toilet all the way to the sewer tap. When you call a plumber about using a camera make sure you ask if the camera has locating. This way if there is something found they can locate the where the camera head is, and depth and be able to mark the ground encase you have to dig it up.
The Following User Says Thank You to Plumber101 For This Useful Post:
LateralConcepts (03-09-2012)
Old 03-08-2012, 11:31 PM   #21
The waste line from the toilet to the sewer tap is in the crawl space. So, is locating still a necessity?
Old 03-08-2012, 11:37 PM   #22
Rewards Points: 616
what is bathroom layout for plumbing
Old 03-08-2012, 11:44 PM   #23
I'm not sure what you're asking (I'm definitely not a pro), but the toilet sits directly next to the tub, and 4 feet away from the sink. The toilet is in between the tub and sink.
Old 03-08-2012, 11:53 PM   #24
Rewards Points: 616
perfect it would be hard to believe it is a vent issue or it would effect one if not both tub and sink
so after plumber snaked line what was his suggestions on how to remedy problem
Old 03-09-2012, 10:37 AM   #25
Unfortunately, that was the limit of his expertise.
I have a camera coming this afternoon.
help with dryer. vent size problem? semidevil Appliances 9 09-06-2013 04:10 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
Vent Pipe Problem? ruffdog Plumbing 20 11-16-2009 07:06 PM
Foundation crawl space vent size problem Constant Improvement Building & Construction 15 01-15-2009 06:07 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
