Problem Tightening Toiled Lid - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2008, 01:43 PM   #1
Problem tightening toiled lid
Hey. My toilet lid is loose on one side, so I'm trying to tighten the nut onto the bolt that holds the lid to the actual toilet. Problem is, first of all, that it's really cramped and it's tough to even get in there.
More importantly, when I try to tighten the nut with a socket wrench, the whole bolt moves along with it, so that the nut doesn't actually move any further up the thread. I've tried using pliers to hold the bolt in place while I'm screwing the nut in, but 1) the bolt is plastic, so I'm afraid this will mess up the thread; and 2) the angle is so bad that this is almost impossible to do, since it takes two hands.
Anybody know of any tool or technique that would help me out here? Thanks.
superbeaver82 is offline   Reply With Quote
Old 07-09-2008, 02:07 PM   #2
Registered User
Termite's Avatar
You're on track using pliers. You should be holding the head of the bolt steady and tightening the nut. Once the nut grabs the underside of the bowl, you'll probably be able to tighten one or the other without having them spin.
If you damage them just get another set. They're cheap and are readily available.
Old 07-10-2008, 09:07 AM   #3
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
You might try getting the nut started on the bolt from underneath, then pushing the nut up against the bottom of the bowl and tightening the bolt from the top. Most of them are like KC says and the nut sort of locks itself against the side if the bowl so it stops turning. Even if not, you won't have to use a lot of motion in the cramped space under the bowl and can do most of the work from the top.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Phone Jack Hookup Problem kennykenny Electrical 21 04-09-2017 10:36 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 03:55 PM
1994 camry rear suspension/tires problem marks5894 Automotive Repairs 2 11-05-2007 05:12 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
