Problem With Sewer Line Leading To Septic Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2009, 12:44 PM   #1
problem with sewer line leading to septic tank
I have a problem with my sewer line going to the septic tank. Every few days it blocks up and I run the electric snake through it and it clears right away. Could I have a problem with venting.
newfie is offline   Reply With Quote
Old 02-16-2009, 01:39 PM   #2
More likely you have a broken line that has dropped a bit at the break and is allowing things to hang-up at this point. Most tanks are within ten feet of the house, so it would be easier to check. Look for standing water between the house and tank or a really damp spot. I use a tee handle probe and you can tell when you get to a wet spot.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-16-2009, 02:23 PM   #3
Our septic tank is buried at least 8 feet and we wouldnt see a wet spot on the ground. We had the ground in our back yard build up alot. Someone told us it is a venting problem. We are very frustrated. we use our electric snake in it every few days and it keeps blocking over and over and it unblocks so easy.
Old 02-16-2009, 04:49 PM   #4
it is not a venting problem. You need to call a septic tank company to come out and pump your tank. While they are at it, they can examine the baffle T and determine if you need a repair. This is not something you can do yourself.
Plumber44 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Frozen Septic Sewer Pipe. econdave Plumbing 11 03-15-2008 05:00 PM
Semiannual sewer backup problem darsunt Plumbing 6 07-07-2007 07:07 PM
Problem with line voltage mehranalmasi Electrical 21 07-04-2007 06:12 AM
Problem with Main Line or Not? reibuild Plumbing 2 05-02-2007 10:41 AM
