#1 |
Problem removing kitchen faucet
How do you remove thin brass nut on a single handle delta faucet .
Kitchen sink faucet. tomie |
#2 |
a picture would definitely help.
#3 |
Super Moderator
Under the sink?
The big one holding the faucet to the sink? I try a basin wrench first---if that doesn't grab--I get my drill and drill the nut in two places and then break the nut free with a screw driver----
New members: Adding your location to your profile helps in many ways.--M-- |
#4 |
retired elect/hvac/plumb
Hammer and small sharp chisel
"facts" have no relevance to this discusion To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Posting from a concrete bunker under a non descript barn |
#5 |
What kind of sink?
Dremel with a cutoff wheel is what I use on rusted nuts. Just score it and bust it off. |
#6 |
PB Blaster and heat if i an getting paid t+m. Chisel if flat rate.
#7 |
Thanks, It is a deep sink, single hole. So I will need a long handle tool or
chisel to remove the nut. My basin wrench jaws will not go around the nut. tomie |
#8 |
If its the style with just 1 nut you might be able to get it off with a 3/8 ratchet and a deep socket,or possibly push the lines out of way and use a 6" cresent wrench
#9 |
Super Moderator
Don't like the idea of breaking the nut by drilling a hole in it? It works.
#10 |
sometimes when its tight for me I disconnect all lines turn top of faucet to break loose then Iam able to get big brass nut off...not sure why your basin wrench won't grab it...mine will
| Display Modes | |
| Faucet Leak below kitchen sink and from the Delta faucet: Replace or Repair? | spyboy | Plumbing | 10 | 03-09-2012 08:25 AM |
| unable to stop leaky kitchen faucet w/ new valve | diy888 | Plumbing | 0 | 02-27-2011 09:45 AM |
| Kitchen Sink Moved - new kitchen | sleepysmurf | Plumbing | 1 | 08-10-2010 07:38 AM |
| Trouble removing kitchen faucet | rebeccac | Plumbing | 12 | 11-29-2009 12:51 PM |
| Replaced kitchen faucet - now less hot water? | sde | Plumbing | 5 | 05-26-2009 04:16 AM |
