Old 05-20-2009, 02:32 AM   #1
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet
Hi,
I have a steady leak coming from a Delta Monitor 1400 series tub/shower single handle faucet. I called Delta, and they told me to order a new cartridge. I was about to start this project, when I ran into a roadblock. The set screw in the handle was stripped. I tried various things recommended by people (use phillips screw driver, torx screw driver, etc...), but nothing worked. I was finally told that I needed to drill it out. It took me a while, but I was able to drill the set screw out. However, the handle still won't come off. I also tried lots of WD40 and white vinegar/warm water combination. So far, no luck. I'm afraid to use too much force on it.
Any ideas on what I might be doing wrong? Any other ideas on how to get the handle off.
Thanks.
kcinsj is offline   Reply With Quote
Old 05-20-2009, 07:25 AM   #2
It sounds like you did not get out all of the set screw. You will probably need to replace the handle anyhow, so I would not be too worried about damage at this point.
Old 06-11-2009, 01:43 PM   #3
Just wondering if you finished repairing the tub
JustaDog is offline   Reply With Quote
Old 09-05-2009, 08:11 AM   #4
I am having the same problem. I tried using an extractor tool, and it broke off. Now, I need a cobalt drill to drill that and the set screw out. Once I do this, where can I get a new handle? Have you fixed yours yet?
Arnierych is offline   Reply With Quote
Old 11-28-2009, 02:29 PM   #5
sorry for the REALLY stupid question. which way to turn (loosen) the set screw. I've been trying counter but it doesn't budge. I don't want to go clockwise for fear of stripping it.
bruckm is offline   Reply With Quote
Old 02-06-2010, 12:30 PM   #6
I found that the set screw can get rusted into place.
Pour some CLR into the hole and let it sit for about 20 minutes.
It should loosen the corrosion up and you can remove the screw.
CLR can be found at most home centers and sometimes even your local supermarket.
Once you get that set screw out removing the handle is just as difficult! Still trying to get mine off.
amihalick is offline   Reply With Quote
Old 02-06-2010, 12:39 PM   #7
Doing it myself
They are probably just corroded together. They make handle pulling tools, not sure if a home store would have one.
6th Period Plumbing Apprentice
Old 02-06-2010, 12:56 PM   #8
How much pressure can I use to pull the handle off? I'm trying to fix a leak not create a bigger one!
Old 02-06-2010, 06:02 PM   #9
Doing it myself
Depends on what the valve is secured to, and how. If it's just secured to the fiberglass, then not much, unless you want to put in a new T/S.
if it's secured to a block in the wall with a nice copper strap, you can probably pull pretty hard, but there's no telling whats actually in there.
Your best bet is probably to find a handle puller.
Your other option (if you're going to buy a new cartridge anyway, is to just cut the handle and the brass spline off of the cartridge so you can access the necessary screws behind the darn thing. Worst case if you screw up your trim plate etc, then you'll need an entire trim kit and not just the handle.
How old is the valve?
Old 02-06-2010, 11:20 PM   #10
oh boy. glad i'm not the only one put in these situations. all the posts above are excellent ideas and solutions. i'd suggest them all. these are the only suggestions i have on the issue. when a setscrew will not back off i hit it with a rust softner CLR's a great one as suggested. second if it won't move. you gotta drill that puppy out. here's the thing don't worry if you over drill a little as the valve *cartridge* you are going to replace also includes the part you may drill into a little. next if it's still not budging as stated above you have to take in to consideration how its fastened. if it won't just flop in the wall. i actually take a mallet and not with a force smack but a bounce smack, hit it up down left right repeatedly and then do it again while pulling on the handle at the same time.this usually is the magic touch on those goobers but if you still have no luck. its time to think about replacing the whole faucet. then you think about, well does the faucet back up to a closet wall where i can cut the sheet rock ect. hope this helps, but i stress with these handles, sometimes after hours of anguish it just takes the right smack at the right place and it just falls off good luck
Austinmv is offline   Reply With Quote
More On This Topic
Faucets should accentuate the overall appearance of your bathroom. You can choose from a large selection available at hardware stores, home centers, bath remodeling showrooms and plumbing wholesalers. You can also shop online. Whether you are replacing... Read More »
Now I'm going to show you yet another high throw drill. Now this would be site swap notated 7, 7, 7, 7, 0, 0, 0. Now the throws are the same as a five, because they're crossing, except that now they're much higher so you have an elongated period of time... Read More »
When you're talking about ball handling. We talked a little bit earlier about figure eight drill. Okay now this one, a little more complex is, and it has two ways you can do it. It's called the figure eight dribble. The difference in the figure eight... Read More »
Hi my name is Jon on behalf of Expert Village in this video clip we will be turning on the water and inspecting our work. If you recall from the beginning of our problem we had a bathtub faucet that leaked, our first point of inspection is just to take a... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be diagnosing our problem. We have a bathroom here that is set up with an older style faucets, now over the years this faucet has develop a leak which has gotten progressively worst... Read More »
Shower faucet problem PlainlyJane Plumbing 16 09-06-2009 08:43 AM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 03:02 PM
Faucet leak problem Chaoz Plumbing 13 08-17-2008 09:58 AM
Help Repairing a 25 Year Old Delta Shower Faucet shapeshifter Plumbing 5 07-07-2008 09:24 PM
Delta table saw blade guard problem RDS Tools 7 03-07-2008 04:29 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
