Problem Refilling Radiator System After Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2011, 12:39 PM   #16
I just took some photos and will upload them shortly.
I am hearing just a few pings and bangs. Could be I need to add more water?
jgoodman is offline   Reply With Quote
Old 02-02-2011, 01:07 PM   #17
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,... Things are warming up, 'n expanding,.. It's gonna make noise...
If the pressure is above 12psi, 'n there's no more air,...
No, don't add more water...
The Pressure is what says to add water or not... Keep it at or slightly above 12psi...
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
septic problem??? jjrbus Plumbing 2 09-09-2009 10:59 PM
Weed problem, bug problem, or both? hayzen Landscaping & Lawn Care 1 08-25-2009 07:33 PM
another brick veneer problem question rdk4609 Building & Construction 6 06-12-2009 10:46 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
