Problem With Old Lavatory Pop Ups - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-18-2007, 10:53 PM   #1
Rewards Points: 682
Problem with old lavatory pop ups
My lavatory pop ups do not work. Looking down the drain there doesn't seem hardly anything left of the pivot rod tip that goes under the pop up plug. Do the tips of pivot rods corrode away? This is a VERY old house.
If I have to replace them, are pivot rods standardized? Do they have the same threads on the retaining nut, and the same washers and gaskets? Again this is plumbing from a house built just after WW 2.
darsunt is offline   Reply With Quote
Old 07-19-2007, 04:35 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
The thing to do is to get a new pop-up rod assembly and try it on your existing drain.
If it doesn't work, replace the drain and tailpiece with the kind with a pop-up assembly.
Just unscrew the old drain to remove it. You might need to heat it up with a hair dryer to soften the old plumber's putty first.
Clean off the old putty, roll a roll of fresh plumber's putty in your hands, wrap it around the sink drain hole under the new drain lip, tighten the drain down and wipe off the excess putty.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
furnace problem captjack HVAC 8 11-23-2007 11:15 AM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 08:08 PM
