Problem With Leaky Sink Drain/tail Piece - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2010, 07:26 AM   #1
Rewards Points: 272
Problem with leaky sink drain/tail piece
Due to our lack of space we were in a position to purchase a pedestal sink for a small bath. But last week and Home Depot we noticed this vanity http://www.homedepot.com/Bath-Bathro...atalogId=10053 that we felt would be a nice change from a pedestal sink. We figured it would have a small footprint while affording us a little storage space.
I installed it yesterday along with a price pfister faucet. While intsalling the drain and tailpiece assembly I noticed that the tailpiece comes through the sink at a slightly odd angle and when I go to tighten the tailpiece against the rubber gasket below the sink it puts it at a slight bind. It doesn't screw up against it flush. If I try to straighten the tailpiece during assembly then it hits the side of the drain hole and won't allow the washer to center up in the hole
Is there a special washer I can purchase that would allow this to work? The tailpiece assembly I'm using came with the faucet and I'm admittetly not crazy about it. I'd be willing to buy a new tailpiece if I knew one that would work better. The vanity is perfect for the bathroom due to the rounded edges of the sink and door clearance.
speedster1 is offline   Reply With Quote
Old 04-30-2010, 08:21 AM   #2
Tail pieces thread into the drain flange. They have very fine threads and are prone to easily cross-thread. Remove the tail piece and make sure the threads are not damaged, and then reinstall it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Tips for HEAVY sink install Sarah24 Plumbing 3 12-04-2008 07:01 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 12:25 PM
Pedistal sink..is this a problem? Dusty Plumbing 6 09-22-2006 02:48 PM
