Problem Installing Water Filter Now Normal Faucet Dont Work - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-22-2012, 09:09 PM   #1
problem installing water filter now normal faucet dont work
hey guys , i wanted to put a faucet for a water filter in the slot where the hose attachment goes in the sink, so i unconnected the hose and didnt know what to do so i cut the ends off the two going into the hose junction that go into what used to be the hose for the spray hose , hooked an elbow to the cold side (i thought ) and put hose to the filter, water comes out the filter but nothing comes out normal faucet , no hot or cold heres a pic of what i did : / anyway i can fix this or do i need a new faucet another problem, i seemed to have stripped the alan wrench thing on the handle so i can get to the hoses from that side , the normal faucet is a delta and its kind with 1 handle
http://imgur.com/E6QnU
any help will be greatle appreciated, thanks
stanlee is offline   Reply With Quote
Old 12-22-2012, 10:10 PM   #2
You did not mention what your experience doing plumbing was. You maybe in a good position to stop now and have someone come out and look at what needs to be done.
paintdrying is offline   Reply With Quote
Old 12-23-2012, 10:39 AM   #3
yeh good idea
Old 12-23-2012, 11:00 AM   #4
DIY staff
Rewards Points: 7,174
Very hard to tell what's going on in that picture---why is your new system hooked into the old faucet?
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
Black material in water filter Sartrean Plumbing 4 03-09-2012 05:31 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
water scaling problem jonathancollins Plumbing 2 10-06-2009 10:40 AM
Water Delivery Problem amadis Appliances 6 12-20-2006 10:22 PM
