Problem With Hose Connections - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2008, 11:52 AM   #1
Whenever I do hose end repair, they always leak. The brass ones are the best I have used with the wormgear clamp, but they still leak. What if I used a sealant when I do the repair? Problem is, I don't know whether I should use Pipe Dope or Plumber's Putty. I have both. Which would be the best choice?
Sasha2000 is offline   Reply With Quote
Old 07-12-2008, 03:39 PM   #2
You might try white teflon paste.
With this paste you don't need to tighten the connections so far down that you're afraid you'll strip the threads (like when installing Fluidmasters).
Old 07-12-2008, 05:16 PM   #3
Not really a threaded connection
There are no threaded connections to this situation. I cut off the end of the garden hose and slipped in a cone like repair end and then a wormgear clamp goes over the hose and tightens down. Water still slips by the repair and soaks anything standing nearby (normally me!).
Old 07-12-2008, 05:36 PM   #4
Same here for this type of problem, and I tried teflon tape and epoxy.
Buy new coupling?
Old 07-12-2008, 10:50 PM   #5
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
You could try using pipe dope on the brass insert before you put it in the hose. It might also be that the hose you are trying to repair just isn't soft enough or the correct size to work with the repair fittings.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 07-13-2008, 08:10 AM   #6
Had to look that one up. . .
"Pipe dope is slang for anaerobic chemical sealant that is used to make a pipe thread joint leak proof and pressure tight. Although common pipe threads are tapered and therefore will achieve an interference fit during proper assembly, machining and finishing variances usually result in a fit that does not result in 100 percent contact between the mating components. The application of pipe dope prior to assembly will fill the minute voids between the threads, thus making the joint pressure tight."
Does it stay flexible after it cures?
Old 07-13-2008, 10:45 AM   #7
I think you are buying the wrong size repair kit. If you use a 1/2" kit for a 5/8" hose, it will leak. Could be that the hose is one made of a hard material (plastic) that does not allow the clamp to fully compress to hold water in the hose. I have repaired many hoses over the years and have had no problems (except for a cheap plastic hose) and never used anything but the kit and clamps. If you are using a screwdriver on the clamp, try a socket and ratchet for more tightening power.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-13-2008, 10:59 AM   #8
Majakdragon, that's it! I do not have much tensile strength and I was using a screwdriver. Will try socket. Thanks people. Am using good quality hoses (which is why I am even bothering with repair). They are still nice and pliable. I only use 5/8" hoses and am using the correct size repair parts. I will add the proper tool and the pipe dope into the mix and that should do the trick. I'll let you know how it works out.
Repairing Electric Central Vacuum Hose jogr Appliances 6 11-11-2008 12:59 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
