Problamatic Shower Head Install. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2010, 07:45 PM   #1
Rewards Points: 272
Problamatic shower head install.
I have a house that has one shower in the basement but the upstairs tub/surround has no shower head and must've only been used for bathing. I'd like to install a shower head in the surround but after having a look at the access panel in the adjacent closest I've noticed that the riser on the shower manifold is plugged and is directly below a framed 2x4. The 2x4 has been cut with ~3-4 inches of clearance above the manifold plug. This 2x4 is directly in line with where the shower head would normally be. What is the best way to deal with this without tearing out the entire surround and remodeling the bath. I can't really afford that right now. I hate to rip the entire wall out to move that 2x4. The walls are plastered.
Anyone have suggestions?
speedster1 is offline   Reply With Quote
Old 01-04-2010, 03:06 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You're going to have to open up one side or the other to do it right.
I would go from the plaster wall side.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Shower Head Pipe Lees73 Plumbing 1 11-04-2009 06:06 PM
Hand held shower head retro Plumbing 4 03-22-2009 03:13 PM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 01:02 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 02:36 PM
Shower Head Draining pinfordend Plumbing 2 05-04-2006 06:30 AM
