Probably Not A DIY Project But A Quick Question About Sewer Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2010, 04:49 PM   #1
Rewards Points: 40
Probably not a DIY project but a quick question about sewer lines
That toilet problem I had posted about a week or so ago has turned into a full blown sewer line replacement. Found a family friend who is a master plumber who gave me a nice price.
Today I came home to find that the mark ups had been done. The gas line mark up is 6 inches to the left of the sewer line mark up.
I am screwed cost wise, aren't I?
TyWebb is offline   Reply With Quote
Old 03-25-2010, 04:58 PM   #2
I don't understand your comment. Are you assuming that one or the other will need to be re-located? I don't know where your located, but that would not present a problem here in philadelphia on a replacement. new construction with new utilities is a diffrent story, They would need to be seperate trenches.
just a guy is offline   Reply With Quote
Old 03-25-2010, 05:03 PM   #3
Rewards Points: 40
I am in Cherry Hill, NJ.
How do you dig a trench with a back hoe with a gas line in the way or near the sewer line? Am I required to re-route one or the other?
Old 03-25-2010, 05:09 PM   #4
No, that is why they mark. your plumber will most likley locate gas service by hand untill he knows exact location and then have backhoe digg the rest. let's face its only sand where your at.
Old 03-25-2010, 05:15 PM   #5
Rewards Points: 40
The plumber is coming out tonight to check it out.
Maybe I am worrying for nothing? I just read horror stories on the internet of people having their cost go up extensively because the sewer and gas lines were too close to each other. It's possible in those cases they were required to reroute one or the other.
If I don't have to reroute, then I guess it shouldn't be a problem.
Old 03-25-2010, 06:51 PM   #6
Rewards Points: 352
Since they are going to dig a trench anyways, and you are dealing with a master plumber he will have the experience and knowledge to decide if you have to move the sewer over it is still just one trench. Unless you want to replace the gas line also why should it cost more to dig a trench two feet over?
I just assumed that your master has experience in residential service, some only do commercial or new construction.
plumberinlaw is offline   Reply With Quote
Old 03-25-2010, 06:54 PM   #7
you are required to hand dig until the pipes are located incase that 6" is not exact
The older I get the better I was
Old 03-25-2010, 07:16 PM   #8
Rewards Points: 40
Plumber came. The PSE&G line is 4 feet deep, the sewer line is 7 feet deep at the sewer outlet near the curb. The gas line is right above the sewer pipe. So it's going to be tough to dig the trench around the gas line.
Gonna call PSE&G and see what they have to say.
Old 03-26-2010, 09:49 PM   #9
Rewards Points: 27
Is it not possible to cut the sewer line up near the home, 45 over and 45 back, then install new sewer in new trench several feet over and parallel to gas? You'll obviously need to "45" over and back to the old sewr near the connection to the public sewer.
cm3putter is offline   Reply With Quote
Old 03-27-2010, 07:48 AM   #10
Rewards Points: 1,216
Some places in the US allow all Utilities to be in the same trench with conditions.
Sewer line the lowest.
Water line above the Sewer.
Electric line on top of the water line.
You can tell why.
NOTE : same trench but staggered.
COLDIRON is offline   Reply With Quote
Old 03-28-2010, 02:23 AM   #11
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
around here the locators are allowed 18" to either side of line plus half the utility,our locators really suck to put it mildly.
im guessing the digger will dig well off to the side of the side of the locate area then hand dig over to find it.
plummen is offline   Reply With Quote
Question about plumbing project tx_kewlgurl Plumbing 1 01-09-2010 08:49 PM
sewer lines altop Plumbing 5 10-28-2009 11:00 PM
cleaning sewer lines with pressure washer ponch37300 Plumbing 3 07-06-2009 09:26 PM
Hi from MA and a quick question laurawoof Introductions 4 10-19-2007 04:26 PM
quick bath tub question bathroomrenovator Remodeling 2 10-08-2007 12:51 AM
